Beware that these builds use CUDA and will not work on login nodes, which does not have CUDA installed as there are no GPUs.
Tensorflow (master build)
Given A100 and CUDA 11 are very new, we have a build of the master branch of Tensorflow which includes better performance and support for these architectures.
Users can utilize them by running this setup script:
source /lus/theta-fs0/software/thetagpu/conda/tf_master/latest/mconda3/setup.sh
This will setup a conda environment with a recent "from scratch" build of the Tensorflow repository on the master branch. The latest
in the path is a symlink to a directory named by date that will be used to track our local builds. Per the writing of this documetation the only build uses latest
points to 2020-11
. In the future, there will be newer builds available in that directory /lus/theta-fs0/software/thetagpu/conda/tf_master/
so check there for newer installs and run the respective mconda3/setup.sh
script to use it. If you find things break since the last time you ran, it may be because latest
is now pointing at a newer Tensorflow build.
This package will also include the latest Horovod tagged release.
Installing Packages
Using pip install --user
With the conda environment setup, one can install common Python modules using pip install --users <module-name>
which will install packages in $HOME/.local/lib/pythonX.Y/site-packages
Using Conda Environments
If you need more flexibility, you can clone the conda environment into a custom path, which would then allow for root-like installations via conda install <module>
or pip install <module>
First, setup the conda environment you want to use as instructed above.
Second, clone the environment into a local path to which you have write access
conda create --clone $CONDA_PREFIX -p <path/to/env>
Then activate that environment:
conda activate <path/to/env>
One should then be able to install modules freely.
