To build python packages for Theta GPU, there are two options: build on top of a bare-metal build (currently not available, but coming soon) or build on top of (and within) a singularity container. Additionally, you can build a new container from nvidia's docker images.
Building on top of a container
At the moment, you will need two shells to do this: have one open on a login node (for example, thetaloginN
, and one open on a compute node (thetagpuN
). First, start the container in interactive mode:
singularity exec -B /lus:/lus --nv /lus/theta-fs0/projects/datascience/thetaGPU/containers/pytorch_20.08-py3.sif bash
From here, you can create a virtual env for installation:
export VENV_LOCATION=/path/to/virtualenv # replace this with your path! python -m venv --system-site-packages $VENV_LOCATION
Note: sometimes, the venv
package is available and if not, you can try python -m virtualenv
. If neither are available, you can install it in your user directory:
pip install --user virtualenv
and it should work.
Next time you log in, you'll have to start the container, and then run source $VENV_LOCATION/bin/activate
to re-enable your installed packages.
Reaching the outside world for pip
packages
You'll notice right away when you try to pip
install you can not, because the connection fails. You can, however, go through a proxy server for pip by enabling these variables:
export HTTP_PROXY=http://theta-proxy.tmi.alcf.anl.gov:3128 export HTTPS_PROXY=https://theta-proxy.tmi.alcf.anl.gov:3128
Now, you can pip install your favorite packages: pip install mpi4py
Building custom packages
Most packages (hdf5, for example, or python packages) can be built and installed into your virtual env. Here are two common examples that aren't currently part of the pytorch container that may be useful.
HDF5
You can find the source code for hdf5 on their website https://www.hdfgroup.org/downloads/hdf5/source-code/. When downloaded and un-tarred, cd
to the directory and run
./configure --prefix=$VENV_LOCATION # Add any other configuration arguments make -j 64 make install
This should get you hdf5! For example, after this:
(pytorch_20.08) Singularity> which h5cc /home/cadams/ThetaGPU/venvs/pytorch_20.08/bin/h5cc # This is my virtualenv, success!
Horovod
Horovod is useful for distributed training. To use it, you need it enabled within the container.
git clone https://github.com/horovod/horovod.git cd horovod git submodule update --init python setup.py build python setup.py install
This should install horovod within your container.
