Submit a Job on Theta
Help Desk
Theta and ThetaGPU
The queuing system used at ALCF is Cobalt. On Theta, Cobalt jobs may run either as script jobs or interactive mode jobs.
Script Method
In the script method, Cobalt will execute a user-supplied script when running a user’s job. All scripts on Theta must have their execute bit set, and must be able to run on a standard x86_64 architecture. Following are the required flags to qsub, as well as some of the more common options. A complete list of options may be found as a part of the qsub manpage, available on any login node.
Required Flags
-n NN - number of nodes (-n 64 for 64 nodes)
-t time - running time (-t 5 for 5 minutes, -t 01:10:20 for 1 hr 10 min 20 sec)
-A Project - project (-A YourProject)
Common options
--attrs - you may specify additional attributes for your job.
          Multiple attribute key-value pairs are colon-delimited.
          The following are common on the KNL nodes:
          - location: a comma-separated list of node ids. Ranges may be hyphenated.
          - mcdram: The desired MCDRAM mode of a job (default: cache)
          - numa: The desired NUMA mode of a job (default: quad)
          The following are common on the GPU nodes:
          - location: a comma-separated list of node names (not IDs). Ranges may NOT be hyphenated on the GPU nodes.
          - mig-mode: Should the GPUs be put in Multi Instance GPU (MIG) mode (default: False)
See: https://docs.nvidia.com/datacenter/tesla/mig-user-guide/index.html
--env VAR1=1:VAR2=2:… - specify required environment variables
-i file - give a file name to be used for stdin
-O Name - name your job and stdout/stderr (-O Job1)
-q queue - queue (only for special cases, such as debug queues (debug-cache-quad, debug-flat-quad))
Note: Remember to give all options before the executable name.
See Submitting to Specific Nodes below to see the difference between KNL and GPU node location specifications. Users will need an allocation on ThetaGPU to utilize the GPU nodes. Request for an allocation by filling out this form: Allocation request. ThetaGPU is listed under Theta on the form.
Example:
qsub -A YourProject -n 256  -t 30  \
--env MYVAR=value1 -i inputdata -O Project1_out \
–attrs mcdram=flat:numa=quad program.exe progarg1
The syntax for Cobalt scripting is slightly different than that of a PBS script. For more information, see Cobalt scripting.
Interactive Method
To run an “interactive mode” job on ALCF Cray resources, add the “-I” flag or “--mode interactive” to your qsub line and omit any executable. Your qsub submission will then wait until nodes are allocated to your job and Cobalt will start a shell on a job-launch node on your behalf. You may aprun against your assigned resources and run other interactive commands from this node. It is important to note that your shell is executed from a launch node and not from your compute head-node. Once your allocation ends, all apruns will be terminated, but your shell will remain for any cleanup actions that you choose to take.
Ensemble Jobs
Users may run an “ensemble job” and combine runs into a single script. This can provide major enhancements to throughput, especially for large ensemble jobs. Users may run multiple jobs in sequence or may use multiple backgrounded apruns to subset their resources among multiple backend executables. There is a system limitation of 1000 simultaneous apruns per Cobalt script job.
Queue Names and Scheduling Policy
Queue names and operations are described on the Job and Queue Scheduling for Theta page.
Queue and scheduling policies can be found on the Queue and Scheduling Policy page.
Project Names
You can find active project names that your account is associated with by running the command:
sbank allocations
If an account is associated with more than one project, a job must be submitted by using a specific project name using -A or by setting the environment variable COBALT_PROJ.
Submitted Job with the Wrong Arguments
If you submit a job with the wrong arguments, you can modify without deleting it and resubmitting it. Most settings can be changed using qalter.
For example:
 Usage: qalter [-d] [-v] -A <project name> -t <time in minutes>
             -e <error file path> -o <output file path>
             --dependencies <jobid1>:<jobid2>
             -n <number nodes of> -h --proccount <processor count>
             -M <email address> <jobid1> <jobid2>
Note: To change the queue, use qmove.
Usage: qmove <queue name> <jobid> <jobid>
Changing Executable after Job Submission
When a job is submitted via qsub, Cobalt records the path to the executable or script, but it does not make a copy. As a result, if the executable or script is modified when there is a deletion or modification, it will affect any jobs already submitted that use that executable. To avoid confusion, it is generally best to avoid making changes after job submission.
Holding and Releasing Jobs
User Holds
To hold a job (prevent from running), use qhold. This will put the job in the "user_hold" state.
qhold <jobid>
To release a job in a user hold (user_hold) state, use qrls.
qrls <jobid>
A job may also be put into a user hold immediately upon submission by passing qsub the -h flag.
qsub -n 512 -t 120 -A MyProject -h myExe
Dependency Holds
For jobs in the dep_hold or dep_fail state, see the section on job dependencies.
Admin Holds
Jobs in the state admin_hold may be released only by a system administrator.
MaxRun Holds
Jobs may temporarily enter the state maxrun_hold if the user has reached the limit of per-user running jobs in a particular queue. No action is required; as running jobs complete, jobs in the maxrun_hold state will be automatically changed back to queued and eligible to run.
Job Dependencies
To submit a job that waits until another job or jobs have completed, use the dependencies argument to qsub. For example, to submit a job that depends on job 12345:
qsub -n 512 -t 10 -A yourproject --dependencies 12345 a.out
For multiple dependencies, list and separate with colons.
qsub -n 512 -t 10 -A yourproject --dependencies 12345:12346 a.out
Jobs submitted with dependencies will remain in the state dep_hold until all the dependencies are fulfilled, then will proceed to the state queued.
Note: In the event any of the dependencies do not complete successfully (nonzero exit status), the job will instead go into the state dep_fail. To manually release a job that is in either dep_hold or dep_fail:
qrls --dependencies <jobid>
or alternatively change the job's dependencies setting to “none”:
qalter --dependencies none <jobid>
Customizing the Output of Qstat
Default fields displayed by the qstat command may be changed by setting the QSTAT_HEADER environment variable.
export QSTAT_HEADER="JobID:JobName:User:WallTime:RunTime:Nodes:State:attrs:Queue""
qstat
​JobID   JobName                           User      WallTime  RunTime   Nodes  State      attrs             Queue
     104927  N/A                               user1     02:00:00  01:20:45  128    running    {'numa': 'quad', 'mcdram': 'cache'}  backfill
     104941  N/A                               user2     00:20:00  N/A       2048   queued     {'numa': 'quad', 'mcdram': 'flat'}   backfill
     104934  xxxx.yyyyy                        user3     04:00:00  01:10:12  32     running    {'numa': 'quad', 'mcdram': 'cache'}  default
     104948  Xxx-YY_ZZ                         user4     02:00:00  00:15:03  128    running    {'numa': 'quad', 'mcdram': 'cache'}  default
     104919  aaaaa_0000_bbbb_c                 user5     06:00:00  01:50:21  64     running    {'numa': 'quad', 'mcdram': 'cache'}  default
     104945  aaaa_bb_cccc-d_eee_f.hhhhhh.iiii  user6     06:00:00  00:18:25  100    running    {'numa': 'quad', 'mcdram': 'cache'}  default
     104848  bbbbbb                            user7     01:00:00  N/A       3624   queued     {'numa': 'quad', 'mcdram': 'cache'}  default
One may specify column headers via the --header flag to qstat.
Available field names can be seen by entering "qstat -fl <jobid>" for any current jobid.
Redirecting Standard Input
To redirect the standard input to a job, do not use the '<' redirection operator on the qsub command line. This simply redirects standard input to qsub, not the job itself. Instead, use the qsub option "-i".
# WRONG
qsub -t 10 -n 64 a.out < my_input_file.dat
# RIGHT
qsub -t 10 -n 64 -i my_input_file.dat a.out
Sbank
The sbank database is updated hourly. This means transactions against your account can take up to an hour before they show up.
Submitting into Backfill Nodes
Sometimes the scheduler will try to clear up room for a large job. During these times, although not many jobs may be running, new jobs are not being scheduled as expected.
At such times, backfill nodes may be available. While nodes are being drained for a larger job, other user jobs may be backfilled onto these resources, provided that their requested wall time is less than the remaining drain time of the set of resources. For instance, suppose that 16 nodes are being drained to allow a 16-node job to run. Of the 16 nodes, perhaps eight are empty and the other eight are running an eight-node job that has 2 hours of wall time left. This allows the opportunity to run a 2-hour, eight-node job in the backfill here.
To discover available backfill, run the nodelist command.
For example:
nodelist
Node_id  Name         Queues     Status                 MCDRAM  NUMA    Backfill
20       c0-0c0s5n0   default     cleanup-pending       flat    quad    4:59:44
21       c0-0c0s5n1   default     cleanup-pending       flat    quad    4:59:44
22       c0-0c0s5n2   default     busy                  flat    quad    4:59:44
24       c0-0c0s6n0   default     busy                  flat    quad    4:59:44
25       c0-0c0s6n1   default     busy                  flat    quad    4:59:44
26       c0-0c0s6n2   default     busy                  flat    quad    4:59:44
27       c0-0c0s6n3   default     busy                  flat    quad    4:59:44
28       c0-0c0s7n0   default     idle                  flat    quad    4:59:44
29       c0-0c0s7n1   default     idle                  flat    quad    4:59:44
30       c0-0c0s7n2   default     idle                  flat    quad    4:59:44
31       c0-0c0s7n3   default     idle                  flat    quad    4:59:44
32       c0-0c0s8n0   default     idle                  flat    quad    4:59:44
33       c0-0c0s8n1   default     idle                  flat    quad    4:59:44
34       c0-0c0s8n2   default     idle                  flat    quad    4:59:44
In this example, a four-node job with a maximum wall time of 4 hours and 59 minutes can be run during this backfill. The backfill times will not always be identical and will depend on the mix of jobs on the partitions that are being drained.
In rare cases, there may be a need to target specific hardware. This may be accomplished using "--attrs location=".
For example:
qsub -t 10 -n 16 --attrs location=0-7,100-107 myprogram.exe
This will force the job to run on those specific nodes. Should that location become unschedulable, for instance, due to a failed node, the job will not be allowed to run anywhere else, without resetting the location attribute. If more nodes are specified in the location field than are required to fill a job’s requested node count, then the first n nodes available in the location set will be used.
Running with a Group of Users
Sometimes it is useful to allow other users to run Cobalt commands on a given job such as qhold, qrls, or qdel. A list of users can be allowed to run commands on your job by submitting a list of users to qsub, cqsub, or qalter using the flag --run_users. Specified users need not be in the same project under which the job was submitted.
For example:
qsub -A FellowShipOTR -n 512 -t 1:00 --run_users frodo:sam:pippin ./council (KNL)
As a convenience, all users belonging to the project under which a job was submitted can be added to a list of users that may control a job by using the --run_project flag.
Users who have been added to the list can run any command that the job-submitter could run on a job. This includes qhold, qrls, qalter, and qdel.
Group Running and File System Groups
While setting this list of users allows any of the listed users to run Cobalt commands on a job, it does not do anything about the permissions of any files involved with the job. Those must be handled by the user(s) setting appropriate permissions on their directories to allow users in their group to read and write files as appropriate. If your project needs a group on the file system to share files or a user needs to be added, email User Support.
More Information
For more information on Cobalt commands, their options, consult the manpages on the system. The same information may be found online in the Cobalt Command Reference.
Using the Job Resource Manager: Commands, Options, and Examples
This document provides examples of how to submit jobs on our systems. It also provides examples of commands that can be used to query the status of jobs, what partitions are available, etc. For an introduction to using the job resource manager and running jobs on Theta, see Running Jobs on Theta
Submit a Job Request
Use qsub to submit a job. (Unlike jobs on the ALCF BlueGene systems, all jobs on Theta are either script or interactive.)
Run the script jobscript.sh with 10 nodes for a maximum of 15 minutes:
qsub -n 10 -t 15 jobscript.sh
To submit jobs to a particular queue, use qsub -q <queue_name>.
To run jobscript.sh with 10 nodes for a maximum of 30 minutes in the debug queue for flat memory mode and quad numa mode:
qsub -q debug-flat-quad -n 10 -t 30 jobscript.sh
Charge a Job to a Project
Use qsub -A <project_name> to charge a job to a particular project.
To run jobscript.sh with 10 nodes for a maximum of 15 minutes and charge the job to MyProject:
qsub -n 10 -t 15 -A MyProject jobscript.sh
To see which projects you are a member of:
You can use the environment variable “COBALT_PROJ” to set your default project. qsub -A takes precedence over COBALT_PROJ.
Delete a Job from the Queue
To delete a job from the queue, use the qdel command. For example for job with ID of 34586
qdel 34586
Depending on the stage of a job’s lifetime, qdel may not complete immediately, especially if the delete is issued during startup on a job that is changing memory modes and rebooting a node. If the job does not ultimately terminate, contact support@alcf.anl.gov with the jobid so that an administrator can take appropriate cleanup actions and administratively terminate the job.
Query Partition Availability
To determine which partitions are currently available to the scheduler, use the nodelist command. This command provides a list of node ids, names, queue, and state as well as any backfill windows.
For example:
% nodelist Node_id  Name         Queues Status           MCDRAM NUMA Backfill
