RAJA ThetaGPU
Help Desk
Theta GPU Nodes
Overview
RAJA is a collection of C++ software abstractions, being developed at Lawrence Livermore National Laboratory (LLNL), that enable architecture portability for HPC applications. The overarching goals of RAJA are to:
  • Make existing (production) applications portable with minimal disruption
  • Provide a model for new applications so that they are portable from inception.
RAJA targets portable, parallel loop execution by providing building blocks that extend the generally-accepted parallel for idiom.
Additional information can be found at RAJA User Guide.
Using RAJA
RAJA provides a project template for how to use RAJA in an application project that uses CMake or Make. This is located at RAJA Project Template.
How to get the source code
The RAJA source code lives at RAJA github
It can be cloned with git clone --recursive https://github.com/llnl/raja.git. The recursive clone will also clone RAJA's dependencies in the proper locations.
Add a cmake configuration for ThetaGPU
raja/host-configs/alcf-builds/thetagpu.cmake
set(RAJA_COMPILER "RAJA_COMPILER_GNU" CACHE STRING "")
set(CMAKE_CXX_COMPILER "g++" CACHE PATH "")
set(CMAKE_C_COMPILER "gcc" CACHE PATH "")
set(CMAKE_CXX_FLAGS_RELEASE "-O3" CACHE STRING "")
set(CMAKE_CXX_FLAGS_RELWITHDEBINFO "-O3" CACHE STRING "")
set(CMAKE_CXX_FLAGS_DEBUG "-O0 -g" CACHE STRING "")
set(CUDA_COMMON_OPT_FLAGS -restrict; --gpu-architecture sm_80; -std c++11; --expt-extended-lambda)
set(CUDA_COMMON_DEBUG_FLAGS -restrict; --gpu-architecture sm_80; -std c++11; --expt-extended-lambda)
set(HOST_OPT_FLAGS -Xcompiler -O3 -Xcompiler -fopenmp)
if(CMAKE_BUILD_TYPE MATCHES Release)
  set(RAJA_NVCC_FLAGS -O3; ${CUDA_COMMON_OPT_FLAGS}; -ccbin; ${CMAKE_CXX_COMPILER} ; ${HOST_OPT_FLAGS} CACHE LIST "")
elseif(CMAKE_BUILD_TYPE MATCHES RelWithDebInfo)
  set(RAJA_NVCC_FLAGS -g; -G; -O3; ${CUDA_COMMON_OPT_FLAGS}; -ccbin; ${CMAKE_CXX_COMPILER} ; ${HOST_OPT_FLAGS} CACHE LIST "")
elseif(CMAKE_BUILD_TYPE MATCHES Debug)
  set(RAJA_NVCC_FLAGS -g; -G; -O0; ${CUDA_COMMON_DEBUG_FLAGS}; -ccbin; ${CMAKE_CXX_COMPILER} ; -Xcompiler -fopenmp CACHE LIST "")
endif()
set(RAJA_RANGE_ALIGN 4 CACHE INT "")
set(RAJA_RANGE_MIN_LENGTH 32 CACHE INT "")
set(RAJA_DATA_ALIGN 64 CACHE INT "")
set(RAJA_HOST_CONFIG_LOADED On CACHE Bool "")
Now build on the ThetaGPU compute node
mkdir build_alcf-thetagpu && cd build_alcf-thetagpu
cmake \
  -DCMAKE_BUILD_TYPE=Release \
  -C ../host-configs/alcf-builds/thetagpu.cmake \
  -DENABLE_OPENMP=On \
  -DENABLE_CUDA=On \
  -DCUDA_ARCH=sm_80 \
  -DCUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda \
  -DCMAKE_INSTALL_PREFIX=../install_${BUILD_SUFFIX} \
Systems
Software
