Quantum ESPRESSO on Theta
Help Desk
Theta and ThetaGPU
What Is Quantum ESPRESSO?
Quantum ESPRESSO (QE) is a suite of codes for electronic structure calculations and materials research. This code uses Density Functional Theory calculations with periodic boundary conditions to estimate energies, forces, and other properties of atomic scale systems. QE runs in parallel (MPI and OpenMP) and is based on plane waves basis functions and pseudopotentials. QE is an open-source project at http://www.quantum-espresso.org/.
How to access Quantum ESPRESSO
Prebuilt QE binaries are provided on Theta under /soft/applications/quantum_espresso. The binaries for v5.3.0 and v6.2.1 are dynamically linked and require certain version of libraries to function. Please read the README file and load necessary modules. The binaries for v6.3 and beyond are statically linked and there is no dependance on loaded modules.
Using Quantum ESPRESSO at ALCF
ALCF provides assistance with build instructions, compiling executables, submitting jobs, and providing prebuilt binaries. For questions, contact us at support@alcf.anl.gov.
If building your own QE is necessary, follow the instruction below.
Building on Theta
This recipe is verified on Oct 12th 2018 with QE-6.3.
QE uses autotools to create a make.inc file required to compile the code. First, obtain a copy of source code on the Theta login nodes.
We suggest compiling the code with Intel Fortran compiler (under Cray wrapper) and using Intel MKL for both linear algebra and FFT. Due to the conflict of MKL and libsci, libsci needs to be unloaded. Enabling wavefunction IO via hdf5 library is optional.
module unload cray-libsci
module load cray-hdf5-parallel
export CRAYPE_LINK_TYPE=dynamic
Inside the source code directory, QE can be configured with the follow command in a shell terminal:
./configure \
 --prefix=/home/myhome/mypath \
 MPIF90=ftn CC=cc --enable-openmp --with-scalapack=intel --with-hdf5=/opt/cray/pe/hdf5-parallel/1.10.1.1/INTEL/16.0 \
 --with-elpa-include=/soft/applications/elpa/elpa-2017.11.001/include/elpa-2017.11.001/modules \
 --with-elpa-lib=/soft/applications/elpa/elpa-2017.11.001/lib/libelpa.a
Now precceed to build the code, use ‘make’ and install it with ‘make install.’
If statically linked binaries are needed, do the following before hitting 'make'
export CRAYPE_LINK_TYPE=static
edit make.inc by replacing
-lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64
in SCALAPACK_LIBS with
${MKLROOT}/lib/intel64/libmkl_scalapack_lp64.a -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_intel_lp64.a ${MKLROOT}/lib/intel64/libmkl_intel_thread.a ${MKLROOT}/lib/intel64/libmkl_core.a ${MKLROOT}/lib/intel64/libmkl_blacs_intelmpi_lp64.a -Wl,--end-group
Running QE Jobs on Theta
Below is an example of a submission script of running the binary pw.x of QE in Theta:
#!/bin/bash
#COBALT -n 8
#COBALT -t 10
#COBALT -q default
#COBALT -A my_project
#COBALT -O my_test
PROCS_PERNODE=16
HT=1
PROCS=$((COBALT_PARTSIZE * PROCS_PERNODE))
NTHREADS=$((64 * HT / PROCS_PERNODE))
pw=/soft/applications/quantum_espresso/6.3/bin/pw.x
echo "Running Cobalt Job $COBALT_JOBID."
aprun -n $PROCS -N $PROCS_PERNODE -cc depth -d $NTHREADS -j $HT $pw -in ./test.in &> ./out
This script file can be submitted as ‘qsub script.sh’, assuming you have a ‘test.in’ file in place.
References
QE User Manual
Alternative Compilations of the Code
Systems
Topics
