conda/2022-07-01 is now the default module loaded by “module load conda" on ThetaGPU. Its libraries use the latest OpenMPI 4.1.4 build on ThetaGPU, and the shared environment contains installations of TensorFlow 2.9.1, PyTorch 1.12.0, Horovod 0.25.0, DeepHyper 0.4.2. The previous default remains available by “module load conda/2021-06-26”. If your workflow has strict version dependencies, we recommend writing your scripts to explicitly load a specific module rather than relying on the default behavior.
