sbank Examples
Help Desk
Account and Project Management
Below is a set of helpful commands to help you better manage the projects you have running at the ALCF.
View your project's allocations
Command: sbank-list-allocations
Use this command to list all of your active allocations for a specific project [Project-X]. This is useful when you need to provide this information in a report.
> sbank-list-allocations -p ProjectX -r all
 Id         Start       End         Resource   Project          Jobs        Charged          Available Balance
 2106       2016-01-04  2017-01-01  cooley     ProjectX              1,139          6,032.8           43,967.2
 2146       2016-01-14  2017-01-10  theta      ProjectX                983      1,084,770.3       25,483,927.5
 6438       2020-09-22  2022-01-01  thetagpu   ProjectX                  3              0.0            2,000.0
Totals:
  Rows: 3
  Cooley:
    Available Balance: 43,967.2 node hours
    Charged          : 6,032.8 node hours
    Jobs             : 1,139
 Theta:
    Available Balance: 25,483,927.5 node hours
    Charged          : 1,084,770.3 node hours
    Jobs             : 983
 Thetagpu:
    Available Balance: 2,000.0 node hours
    Charged          : 0.0 node hours
    Jobs             : 3
List your project's quota on Grand and/or Eagle File system
> sbank-list-allocations -p ProjectX -r grand
 Allocation  Suballocation  Start       End         Resource  Project      Quota
 6687        6555           2020-12-16  2022-01-01  grand     ProjectX    1.0
Totals:
  Rows: 1
  Grand:
    Quota: 1.0 TB
> sbank-list-allocations -p ProjectX -r eagle
 6688        6556           2020-12-16  2022-01-01  eagle     ProjectX    1.0
Totals:
  Rows: 1
  Eagle:
    Quota: 1.0 TB
List only the created timestamp field for all allocations that were created before 01-01-2015 for ProjectX accross all resources
> sbank-list-allocations  --created "<20150101" -r all -p ProjectX "-f created"
 Created
 2016-01-04
 2016-01-14
 2016-01-15
Totals:
  Rows: 3
Date  filters (UTC): created < "2015-01-01 00:00:00",
List all active allocations for all resources for project ProjectX and add the field Created to the display list
shrubbery~ > sbank-list-allocations -r all  -p ProjectX -f "+created"
 Id         Start       End         Resource   Project          Jobs        Charged          Available Balance  Created
 279        2011-08-30  2020-01-01  theta      ProjectX              6,361     12,332,699.9      -12,332,699.9  2013-02-22
 2106       2016-01-04  2017-01-01  cooley     ProjectX              1,150          6,080.9           43,919.1  2016-01-04
Totals:
  Rows: 2
  Theta:
    Available Balance: -12,332,699.9 node hours
    Charged          : 12,332,699.9 node hours
    Jobs             : 6,361
  Cooley:
    Available Balance: 43,919.1 node hours
    Charged          : 6,080.9 node hours
    Jobs             : 1,150
List all available fields for the sbank-list-allocations command
> sbank-list-allocations  -f "?"
available fields:
 id
 start_timestamp
 end_timestamp
 resource
 project_name
 jobs_count
 charged_sum
 available_balance_sum
 created_timestamp
 award_category
 award_type_name
 admin_name
 cbank_ref
 comment
View your project's users
Command: sbank-list-users
List all charges for userx on theta on project ProjectX
> sbank-list-users -p ProjectX -r theta -u userx
 User             Jobs        Charged
 userx                 1,814          9,884.5
Totals:
  Rows: 1
  Resources: theta
  Charged: 9,884.5 node hours
  Jobs   : 1,814
List charges for all users in ProjectX on Cooley.
  • This works for project leads (i.e. PIs, Co-PIs, Proxies), since they can see everything in their own projects.
 User             Jobs        Charged
 user1                   120          4,243.7
 user2                     0              0.0
 user3                     0              0.0
 user4                   181          1,195.5
 user5                     0              0.0
 user6                 2,560         10,868.7
 user7                     0              0.0
 user8                     0              0.0
 user9                     0              0.0
 user10                    7              3.5
 user11                    0              0.0
Totals:
  Rows: 11
  Resources: theta
  Charged: 16,311.4 node hours
  Jobs   : 2,868
View your project's jobs
List jobs for user "userx" for jobs that started in the range 2016-02-15<= started < 2016-02-29 and add the transactions related to the job
Command: sbank-list-jobs
  • Note:
    • The job with the refund
    • transaction_ids_list field can be shorten all the way to "t" in the -f "+ t"
shrubbery~ > sbank-list-jobs -u userx -f "+ t" -S "2016-02-15...2016-02-29"
 Id         Jobid      Resource   Project          Allocation  User       Duration   Charged          Transaction Ids
 1013857    730417     theta       ProjectX         1740        userx      1:53:07           61,776.8  CHARGE-1011230
 1013860    730558     theta       ProjectX         1740        userx      1:53:07           61,776.8  CHARGE-1011233
 1014168    730668     theta       ProjectX         1740        userx      1:53:25           61,940.6  CHARGE-1011541
Totals:
  Rows: 3
  Theta:
    Charged      : 185,494.2 node hours
    Duration     : 6:44:00
Date  filters (UTC): "2016-02-15 00:00:00" <= start < "2016-02-29 00:00:00",
List the nodes used, runtime and start timestamp for Cooley job 744160
Note to display the date and time we increased the the number of characters of start_timestamp to 19
catapult~ > sbank l j -r theta -j 50576 -f "jobid nodes_used runtime start_timestamp:19" Jobid Nodes Used Runtime Start --------- ---------- --------- ------------------- 50576 512 1:00:49 2013-01-16 21:49:30 Totals: Rows: 1
View your project's transactions
Command: sbank-list-transactions
List of transactions that where at or after 2016-02-29 for ProjectX add fields: job_duration, nodes_used and hosts
  • ## Note the following:
    • job_duration, nodes_used and hosts are shorten, but they are still uniquely identified
    • host has the left justified width of 20, specified as "h:-20"
catapult~ > sbank-list-transactions -p ProjectX --at "ge 2016-02-29" -f "+ job_d nodes_u h:-20" -r theta
 Id         Resource   Project          Allocation  At          User             Transaction Type  Amount           Jobid      Job Duration  Nodes Used  Hosts
 1025426    theta       ProjectX         2147        2016-02-29  userx            CHARGE                   48,005.1  740587     1:27:54       2048        MIR-00800-33BF1-2048
 1028046    theta       ProjectX         2147        2016-03-01  userx            CHARGE                  147,647.1  742090     4:30:21       2048        MIR-40000-733F1-2048
 1028755    theta       ProjectX         2147        2016-03-02  userx            CHARGE                1,576,068.0  742126     6:00:44       16384       MIR-04000-77FF1-1638
Totals:
  Rows: 3
  Theta:
    Charges Amount: 1,771,720.2 node hours
    Job Duration  : 11:58:98
Date  filters (UTC) : at >= "2016-02-29 00:00:00",
