sbank-detail-allocations
Help Desk
Account and Project Management
sbank-detail-allocations [options] [<allocation id> ... <allocation id>]
Detail allocation information. NOTE: 1. The list of <allocation id> arguments are optional. 2. you can also enter <allocation id> list by using the -a option multiple times. 3. regardless, both are optional, and you can get detail allocation info using the option filters below.
OPTIONS
--version
show program's version number and exit
-h, --help
show this help message and exit
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID
filter on allocation id
-e EVENT_ID, --event-id=EVENT_ID
filter on event id
-f FIELD_INFO, --field-to-display=FIELD_INFO
FIELD_INFO is <FIELD>[:<WIDTH>], for available fields enter -f? or -f "?", to add fields enter -f "+ <FIELD>[:<WIDTH>] ..."
-j JOBID, --jobid=JOBID
filter on jobid
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY
set number of fields to display
-p PROJECT, --project=PROJECT
filter on name or id, DO NOT MIX, enter 'all' to get all, wild cards '*' is allowed but only on names
-r RESOURCE, --resource=RESOURCE
-t TRANSACTION_ID, --transaction-id=TRANSACTION_ID
filter on transaction id
-u USER, --user=USER
-w "FIELD_INFO", --field-width=
"FIELD_INFO" FIELD_INFO is <FIELD>:<WIDTH>, for available fields enter -w? or -w "?"
-E END, --end=END
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge, gt, le, lt, eq or >=, >, <=, <, ==. Operator Defaults: OPER1 is 'lt' for single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry. Date Parsing Precedence: YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov 1, 2012
-H, --human-readable
abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions), ...
-I, --get-inactive
also get inactive allocations
-O, --get-only-inactive
only inactive allocations
-S START, --start=START
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge,gt,le,lt,eq or >=,>,<=,<,== , Operator Defaults: OPER1 is 'ge' for single date entry, OPER1 and OPER2 are 'ge' and 'lt' respectively for range date entry, Date Parsing Precedence: YEAR then MONTH then DAY, i.e. 121101 is parsed as YYMMDD, hence Nov 1, 2012
-T TRANSACTION_TYPE, --transaction-type=TRANSACTION_TYPE
transaction types: CHARGE, REFUND, PULLBACK, DEPOSIT, VOID
--award-type-name=AWARD_TYPE_NAME
filter on award type name
--award-category=AWARD_CATEGORY
filter on award category
--cbank-ref=CBANK_REF
filter on Clusterbank reference id
--created=CREATED_TIMESTAMP
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge, gt, le, lt, eq or >=, >, <=, <, == . Operator Defaults: OPER1 is 'ge' for single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry. Date Parsing Precedence: YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov 1, 2012
--debug=DEBUG_LEVEL
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2
--get-deleted
also get deleted objects
--get-only-deleted
only deleted objects
--all-charges
only show list info that have charges regardless of project/user relationship
--history-date-range=END
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge, gt, le, lt, eq or >=, >, <=, <, ==. Operator Defaults: OPER1 is 'ge' for single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry. Date Parsing Precedence: YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov 1, 2012
--last-updated=LAST_UPDATED_TIMESTAMP
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge, gt, le, lt, eq or >=, >, <=, <, ==. Operator Defaults: OPER1 is 'gt' for single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry. Date Parsing Precedence: YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov 1, 2012
--no-commas
remove commas from comma separated thousands
--no-header
do not display the header
--no-history
do not show history information
--no-rows
do not display the row data
--no-sys-msg
do not display system message
--no-totals
do not display the totals
